DanTheRVMan
Jul 24, 2013Explorer
Trap wrote:
Dan as HiTek pointrd out the difference in the cool to colder weather is huge in how warm you stay, with dual pane windows
If you reread his post he mentions the alaska pak and the gives all credit to the dual pane windows without considering anything in the alaska pak
The difference in the windows is small - there will be condensation as I have mentioned - you fail to consider the size of walls, ceiling, front windows, floor, and plastic roof vents.
Failing to consider the affects of an alaska pak show the bias in your evaluation.
Yes the windows are slightly different, but the total area of windows is small in comparison to all other components so there is not a huge affect other than the fogging at the windows.
