John_Wayne
Sep 08, 2015Explorer II
I did it on mine you don't have to drop the tank to the ground just low enough to reach the connection. On mine it helped to have shims to hold the tank brackets away from the frame because everytime I jacked the tank up the brackets would slide the keeper holding the nut that the tank bracket bolts went through ( you'll see what I mean when you go to drop it) I also replaced my fuel line with a metal line and used fuel injector rubber fuel hose for the connections.
Have fun good luck did mine using 1 rolling floor jack and one bottle jack.
38,763 PostsLatest Activity: Dec 05, 2025
