bobndot wrote:
The replacement tv type will depend on how you use your rv.
My 40” is a 12 volt model but uses 65 watts.
Could you share what brand and model 40" you have that operates at 65 watts?
Our 26" 120V Samsung TV runs very hot, so much that I installed a computer fan behind it to cool it down. It's confinement does not help the situation. A new edge-lit 32" 12V TV may use much less power, hence run cooler and use less energy.
Our 26" has lots of frame. For a while now, the 32" is almost frameless so the over-all size is the same. I'd like to compare the specs on power consumption of what I have to what I would buy to determine if it is worth the effort and cost.
Here is our 26". It is mounted securely without an arm. There is not a lot of breathing room around it....air circulation is poor.
