dan23
May 24, 2013Explorer
Replacing shower sky light... How?
The outer panel of the two-piece (inner and outer) sky light in my 1998 Winnebago Brave has a few cracks which have been repaired with silicone caulk. I have a replacement sky light on it's way to me, but before beginning the actual work, I thought asking here for help would be a good idea.
What's the easiest way to remove the self-leveling sealant that was used to install the existing sky light? The RV roof is fiberglass.
What's the best readily obtainable sealant to use when installing the new sky light? I will also use screws as per the existing sky light. One sky light manufacturer's site said to drill the hole one size larger than the screw and to use a rubber washer to avoid stress on the plastic.
What else do I need to know? Your helpful comments will be greatly appreciated.
