JC2 wrote:
Am seriously thinking about replacing the Tracvision domed sat on our 04 Newmar Dutch Star with a Winegard SK-SWM3 Slimline Automatic Multi-Satellite TV Antenna and mounting it on Winegard Travler Metal plate.  For those that have done this, where you able to mount the new in the same place as the old and did the screw holes line up?
Save the $125 for the base plate, it is completely unnecessary on your coach.  Yes, it "should" go where your dome is now depending upon how close to your front A/C unit it is mounted.  In any case, it will go in that general area and any holes left from the previous dome installation are sealed up by putting a dab of caulk in the hole, screwing the old screw back in that hole and then caulking over the top.  No leaks and a Trav'ler that will make you wonder how you ever got by without one!
