memtb's avatar
memtb
Researching Class C Motorhomes
We have been researching 2005 - 2009 Class C motorhomes. We wanted a Bigfoot as it was supposed to be very good for winter use with double pane windows and the way it heated the underbelly but they are hard to come by so we've regrouped and are looking at others that might fit our criteria. We also need something that would be able to pull a boat weighing about 5000 lbs.
So far, I've found that the Winnebago Ascent also has double pane windows and it appears that the majority of the homes all have heated underbellies. To make our research a bit easier, I was wondering if the members on this site, that owned the older, 2005 - 2009, Class C motorhomes, 22' - 27', would give us their pros and cons on the homes they own. Also, it would help if you would let us know how long you have owned your home as I believe the longer you own a home, the more critical or appreciative you are with the home. I'd appreciate any advice a member can give to assist in our search. We've owned small campers, tent campers and 5th wheels but never a motorhome so is a new adventure for us. Thanks for any information or advice you can give us.
  • Hi
    26 feet is the ideal length to wheel base ratio. I would look for one of these: http://www.lazydaze.com/
    Cold weather use and slides don't mix. That is why Lazydaze units are desirable--no slides.
