- bobndotExplorer III
Curious what you mean by not much top end
What rpms in 10th gear at 70-80-90mph?
75-80mph 10 sounds about right.
Try to keep it under 115 mph ok ? :B - Grit_dogNavigator III
CaptJD wrote:
It has so much torque but not much top speed IMHO. ... When I started for the first time and heard the engine I thought exhaust muffler was off. .
I feel I am not going to RVing but rather joining to a drag race every time I hit the ignition switch!
On a 19ft (20' overall) C class it gives me only 10mpg if I am lucky.
Sounds awesome!
It should have ALOT of torque in a lightweight vehicle such as yours.
Curious what you mean by not much top end. What gears do you have?
Even deep gears should still cruise very comfortably at WELL OVER freeway speed limits. What rpms in 10th gear at 70-80-90mph?
10mpg doesn't sound "bad" what kind of speeds? Cruising at 60-65, I'd expect more. 75-80mph 10 sounds about right. - btimExplorerWe bought a new Entegra Class C in December. Has the 7.3 motor. Only have 1,500 miles on it thus far but I am impressed with its power. The RV is almost 27 feet long and is 11'8" tall. Weighs almost 11,600lbs, with a GVWR of 14,400lbs. As a result there is considerable weight and wind resistance on the highway. I do not exceed the speed limit, and generally cruise at 65mph on the highway. Mileage has been about 9.5mpg. Towed a 4,ooolb car about 180 miles and still got just under 9mpg (all flat land thus far). Taking it out west this summer and will be towing a small car. Hoping to see 9mpg, but I know the mileage will drop in the mountains.
Overall the 7.3 motor has plenty of power for this size rig. I imagine it will be more than adequate in a smaller rig. - mleekampExplorerI'd say it's more about the wind resistance than the weight of your RV that affects mileage. 10 is very good. Pulling our toad or not, we get 7.5 mpg, and yes, that is the V10, not the 7.3 V8.
So 10 mpg is good to me! - CaptJDExplorerWell, last Wednesday I've purchased a Thor Coleman 19CM and it came with that 7.3 engine...
I think it's a little overkill for that tiny motorhome but in any case so far I drove her from AR to CA via Southern route by El Paso due to bad weather along the N route.
It has so much torque but not much top speed IMHO. But again I am no expert. When I started for the first time and heard the engine I thought exhaust muffler was off. At home I drive a 3.5L EcoBoost engine Ford Transit 350 XLT. My poor XLT feels like Mercedes SL550 in noise comparison to the 7.3L V8...
Gas guzzler for sure. On a 19ft (20' overall) C class it gives me only 10mpg if I am lucky. A little bit of wind or uphill climb I am down to 8-8.5mpg.
I was expecting to get at least 12mpg or so on such a tiny C class but I guess it was wishful thinking on my part!
So far after 2200 miles not much to brag about. But today I've found Ford already issuing a recall on this engine and E350 bodies for some sort of heat shield issue I assume.
So waiting for the postman!
38,764 PostsLatest Activity: Dec 23, 2025
