My 2014 35ft Itasca leans to the right. Trust me its not a weight issue unless it came from Iowa that way. Do others have that problem? Will air bags fix the problem? Front or rear? Thanks
I had a bad rear air bag which made it lean to the left. If your air bags are ok and even if you don't have the weight distributed right you should still be able to adjust your leveling valves to compensate. On my coach I have one leveling valve in the front and two in the rear.
