Makin__Do's avatar
Makin__Do
Roadmaster vs. Safe-T-Plus
Looking for opinions on steering stabilizers. Have an older 70's
Dodge B300 class c and would like to tighten up the steering. Already replaced the gear box, tie rod ends and ball joints. Still looking for a tighter feel and quicker return to center, more like todays steering.
Both Roadmaster and Safe-T-Plus have the same claims for their steering stabilizers with a little different approach. Without considering price, would like to hear from those that have installed these products and their experience with them on the road.
  • j-d's avatar
    j-d
    Explorer II
    I agree with Harvard.
    That said, we had a 1971 Doge B300 Window Van. I spell that out because it was NOT dual wheel or RV chassis. But the way the front end was laid out, it had two Idler Arms. Those were critical to tightness of steering. Also, I replaced Control Arm Bushings along with Ball Joints. That too made a difference.
    Re: S-T-P vs. Roadmaster (REFLEX I believe is what you are asking about). Two things favor S-T-P:
    1. It uses TWO springs in opposition to help find "center." Reflex uses one. Off center in one direction, that spring does its job in Compression. Off center the other direction, same spring is working in Tension. The S-T-P design makes more sense to me.
    2. An outfit in Oregon called Henderson's Line-Up is famous for its work in RV Ride and Handling issues. They have very close ties to Roadmaster but their steering stabilizer solution is S-T-P. That endorsement speaks volumes to me.
    We do have an OP here who had a spring break inside the shielding of an S-T-P. The power steering force required to overcome the resulting jam damaged part of the frame. That's Bryan and he uses his rig HARD. Only documented case of a problem with an S-T-P here at RV.net.
    My take: Be sure the ENTIRE Suspension/Steering are OK and that it's in proper alignment. Add a little Caster if you can, more than mid-spec range, but not more than max spec range, and see what it does. THEN consider an add-on. Your front end is more like the Stable Chevys than the Wandering Fords. Getting it all tight might be enough.
  • Makin' Do wrote:
    ....... Still looking for a tighter feel and quicker return to center, more like todays steering.
    Do you realize the same benefits can be achieved by increasing the front end Caster Angle?
