I have a 2018 Fleetwood Bounder the rockerswitch fore the front blinds wont raise the blind it will go down NOT up. I got the switch apart jumper to get it to go up. loohing for switch cant find one...
Try this... Cycle the switch UP/DOWN UP/DOWN like 100 times while it is NOT connected. then re-connect and try again. If it does not work, well at least it was FREE if it does work consider "Should I buy lotto tickets cause when you hot, you hot" or "Should I NOT buy lotto tickets because i used up my quota of LUCK for the month"
Worked for me, in Las Vegas, different switch and I did fairly well that week, Did not win big but did not lose either.
