B.B.Upch wrote:
Thanks.. it is not riveted... it is washer with a screw coming thru it... it appears u have to unscrew it from the underneath side.
Tiffin NEVER installed clearance lights from the back side. I have NEVER (in 37 years) seen any exterior clearance light installed from the backside. IF it is indeed screwed from the inside of the capo. someone else did that, not Tiffin. If you determine they need removed from the backside, I would remove the clearance light by breaking it off, cut off the screws and install correctly from the front. Doug
