mike_brez's avatar
mike_brez
Roof top heat pump/furnace issue
I replaced my roof top ac’s with two Dometic 15,000 Penguin II Low Profile Air Conditioner Heat Pump units with 10 button thermostat.
I tried to fire up my webasto coolant heater and when I put the thermostat on hp or furnace the roof tops run. When on furnace the roof top should not run.
Thanks in advance for any help/suggestions
  • Do you have the FAN set to AUTO? Doug
    Fan Speed Press the FAN button to select the desired fan speed. Each successive press will advance to the next available speed. Your selections will be Auto, LOW, MED, and HIGH. The fan will run continuously during LOW, MED, and HIGH fan settings. The fan will cycle on and off with the thermostat on AUTO setting. See “Special Features” on page 8 for more information on auto fan.
    To set Aqua Hot instead of furnace.
    “FURN” / “AQUA” - Furnace or Aqua Mode (Factory setting is “FURN”) To change the setting from “FURN” to “AQUA” or visa versa, simultaneously press the up and down buttons. The LED will display the selected option.
