mike_brez
Jun 19, 2019Explorer
Rooftop ac repair
Ok both my rooftops are not working. Dometic Duro Therms.
Took covers off and installed peircing service valves. Both had no freon. Both had pin holes in capillary tube in same place apparently rubbing issue. Cut sheet metal to access. Put a drop of braze on one and cut one out and sleeved with a peice of 1/4 inch tube and brazed. Pulled a vacuum on both and filled both with 24.5 oz of r22.
Wasn't very warm but shot the rear plastic ac grate with ir gun 67* fired up generator turned rest ac an feels cool 15 min shot plastic ac grate again in same spot 48*
Shut down rear and started front. Fan comes on but compressor keeps on trying to start every minute or so and cuts out. Removed wires from compressor and all have continuity. Switched all capacitors and compressor over load switch from working rear to front and no change. I guess compressor is locked up. Was thinking of trying a hard start kit but not sure it would work. Was thinking about trying to find a compressor but a quick search showed nothing. Gotta hop back on roof and get numbers off it. Here's a few pics.
