MSU_Dog_Hauler's avatar
Aug 20, 2019
Rooftop AC Tripping Breaker... Sometimes
I have a 2001 Monaco Knight with 2 Dometic Duo-Therm AC units. The Rear air works fine and the front has started tripping the breaker. I have cleaned both sets of coils, replaced both capacitors, replaced the motor and installed a new breaker. The unit will run and cool fine all night, but when the sun comes up and the temp starts to rise above 85 or so, the breaker will trip. I can wait an hour or so, and re-set the breaker and it will start up again, but only run less than a minute before it trips it again. If I wait till the sun goes down and the temp drops it will not trip until the next morning. The system has never been tapped, so I don't know about the freon level. Anybody have a similar experience I can learn from? Thanks in advance for your help.
  • I assume that where you are parked the voltage is stable and not going up and down. Circuit breakers will wear out so you might try replacing the breaker that is tripping. Also at some electronic stores you can buy an aerosol can of spray coolant. With this you can spray individual components to see if cooling any of them solves your problem.
