No question that on these shorter and lighter motorhomes a load helps the ride. Koni shocks can make a difference as they are not as stiff as Bilsteins and if you want to unload 6 grand the Kelderman air ride will make an enormous difference. These lighter shorter wheelbase motorhomes do not ride like the larger ones that have more weight so a lot of tweaking can get expensive to get them where you are comfortable. As had been indicated tire air pressure is critical. When the service rep put 95 into my tires instead of 80 even my Kelderman couldn't help it.
