2oldman wrote:
Scottiemom wrote:
Refrigerator is not working on electric. I knew this before I left, so it's running on gas.Turns out fridge works fine on electric, but the receptacle in the fridge box does not work.
Ok, you've lost me here.
a) refer not working on electric
b) works fine on electric
c) what is a receptacle in the fridge box?? I assume the 120v
"With regard to the fridge, there is no juice going to the outlet. Glen checked the converter for broken wires, "
The converter has nothing to do with 120v.
Help.
The Dometic Fridge does not work on electric as it is configured. It has an electric receptacle in the fridge box it is plugged into. When set on auto, it runs solely on gas because there is no power to that recep. If you take the cover off outside, you can see it plugged into an outlet. That outlet is not working. It is working on gas. In testing, they found if they unplugged the fridge from that receptacle and plugged it into power via an extension cord, it works perfectly. So it is working on electric and gas, but won't work plugged into the receptacle inside the fridge box. So it is either a bad receptacle or there is a broken wire between the converter and the receptacle in the box.
Perhaps I said it incorrectly, but they opened the box, which I thought was labeled converter. It is where all the power comes in and has fuses and breakers and the power surge protector. Everything in there checked out, and wires go from there throughout the coach. So that's why they checked that.
Dale
