Lititz55's avatar
Lititz55
Running hot
It run hot 210 to 240 I put a new thermostat in .
Both the electric and the motor fan works.
its a 1992 winnebago Brave 30ft with a 454.
Thank
Jim
  • You indicate the electric fan and the motor fan are working. The motor fan may appear to be working but not engaging (locking) when the temperatures reach a preset temperature. You should hear the engine start to roar when the fan locks in at a higher temperature. If you don't hear this roar (like downshifting a gear or two) then the fan clutch is faulty. Not an uncommon problem.
    If you do hear the roar then I'd suggest a good internal/external cleaning of the radiator.
  • I put new radiator cap on it call for 15lb
    water pump how do you know if one going bad i have no leaks.
    the gauge is good i took a infrared and it about the same.
    radiator is good only has 54000 miles
    Thank
    Jim
