Ed_Gee
Aug 13, 2016Explorer II
deprived wrote:
We got weighed at Escapees in Livingston , Texas. Subsequently I set the tire pressure according to the Michelin table. The back tires felt great but the front felt a little squirrelly so I dropped them by 5lbs psi and it drives much better.
Other than tire wear, is there and danger or disadvantage to running the tires a little bit low?
Absolutely! Lower pressure induces higher running temperatures...which can lead to tire failure. SOP is to run tires 5% higher than Michelin recommendations as a safety factor.
38,766 PostsLatest Activity: Jan 10, 2026
