wolfe10
Aug 13, 2016Explorer
Be aware that using your actual wheel position weight, selecting the heavier wheel position on that axle and going to the inflation table gives you the MINIMUM PSI FOR THAT LOAD-- all tires on an axle to have the same PSI dictated by the heavier wheel position.
Yes, the big danger is a blowout. Carrying less than recommended pressure= (yes, is the same as) being overloaded.
You do not mention what chassis you have-- please post.
And, by "Squirrely" please describe more fully.
38,766 PostsLatest Activity: Jan 10, 2026
