Sam_Spade
Aug 13, 2016Explorer
j-d wrote:
It's an E450.
The E450 has an alignment defect that needs to be corrected if you feel the steering is wandering; probably applies to all models that use it for a chassis. There are threads on here about it. Did it on mine and it made a WORLD of difference. Doing a search for caster or camber should find it (sorry I don't remember which). Maybe someone else will.
And since this is a class C, I still think that obsessing over tire pressures is....obsessive. 80 rear; 65 front should serve you fine even if you go up a load range, unless you have done something to drastically alter the total weight or front to back distribution.
38,766 PostsLatest Activity: Jan 10, 2026
