the silverback wrote:
If you intend to park it for a long time put something under the tires between them and the concrete pad. Both Michelin and Goodyear say this needs to be done. Maybe there is something on their web sites. I remember a engineer from Michelin saying a piece of plywood is OK. Please check it out.
Yes. I am full-timing now and it was recommended that there be a barrier between the ground (concrete etc.) and the tires. I use wood and also have a vinyl place mat above the wood. It is said that the concrete will leach the oils from the tire. This is more important than tire covers.
