Kwikee steps go in when I shut to door and out when I open the door when the key is off. I know they should stay out when the key is off and go in and out when the key is on. I have a step switch o...
There is a separate fuse for the manual wall ON /OFF switch. Usually a 5 amp. FIND that fuse for the wall step switch. IF that circuit is DEAD, the steps operate as you describe. Doug
