Dougrainer, Thanks for the tip on the fuses. Found them both and they are okay (good) Still same problem with steps.
I checked Kwikee website and it does not address this problem. I disconnected the switch on the wall and no change. Any more hints?
Ernest, thanks for responding and you are correct in that since I had battery problems many things have happened. But thanks to that, I have learned where all the fuses are, how to test them, what they control and fixed my battery drain. So lots of good has come from my battery problem. Arnold
