Hi all, Planning on getting a water softener prior to our trip out west this summer. I am looking at the Flow-Pur RV 10,000 that sells for $192.00. It says it will do the job and I do use their produ...
Hard water can completely plug your plumbing system, particularly the check valves. It is so bad where I live that every couple years we have to drain our 50 gallon hot water tank and vacuum the white calcium sediment off the bottom of the tank. If we don't do the the tank elements quit heating the water. I had similiar sediments in my RVs system. A Flow Pur Mark 8000 and some valve replacement solved all my problems. Brought it straight from the factory. They are RVers too!
