becker's avatar
becker
RV Wi Fi System
The desktop computer in my coach (see signature for particulars) does not have a wifi board installed in it. I have obtained a Netgear AC1200 High Gain WiFi USB Adapter that I plan on installing in one of my computer USB ports. I also have a Verizon 4G Hotspot. I also plan on getting a Wilson Sleek 4G + 23dB Amplifer Kit #460107 to round out my system. (I understand this kit has an antenna with it that really helps plus there is a cradle that I can put my hotspot in that also helps out.)
My question to you gurus out there is: Is this the way to go and/or could you suggest a better way?
As you can probably tell, I'm out of my element on this situation and really need help. I will humbly appreciate any suggestions that will improve on the above.
