wolfe10
Dec 21, 2013Explorer
Here is the info I measured for the REAR sway bar bushings on 1997 Safari Sahara leaf spring suspension-- measure yours to verify if they are the same. Very easy to remove one end link nut on each side to drop bar and measure. No jack or other tools needed.
If you find a replacement of the dimension below PLEASE POST or PM me.
Rear sway bar: dimension of the axle plate machined to accept the end link-- they are more restrictive than the sway bar end: Axle plate is 1" thick. Through drilled .75" Centered on the .75" hole is a .25" deep by 1.5" diameter recess above and below. The bolt securing the end link is .5" diameter. SO, the 8 end link bushings need to be: OD: slightly less than the 1.5" to fit into the 1.5" recess (#3 above). Old bushing measures 1.25", but this dimension is not critical as long as it is less than 1.5". ID: 1/2", based on bolt diameter (#4 above). Nipple OD: .75" diameter and up to .25" tall. (Nipple may not be the proper term-- it is the part that fits deepest into sway bar and axle plate.). Diameter to fit into .75" diameter hole (#2 above). Depth to fit into .25" deep recess (#3 above). The sway bar end link attachment point is likewise machined .75" diameter and is .75" thick.
38,705 PostsLatest Activity: Jan 24, 2025
