jassrnj wrote:
I'm looking at a 1999 Safari Serengeti - I know there are problems with the velvet ride and I want to be sure of what I'm getting.
If ride height is the problem how can I tell how high it is suppose to be. How does the problem effect the stability and handling of the RV . What are the solutions for resolving problems with the Velvet Ride system. Can I add air bags to compensate for the problems
Thanks for you info.
John
I Highly recommend passing on the Safari with Velvet Ride as the suspension replacement parts availability is dicey. If the suspension is healthy (none of the tubes have failed) yes you can add air ride. There is even a kit available. The guy that bought my Safari was doing exactly that. IMO unless the deal is just crazy good I would just pass altogether.
