I am thinking about adding this steering stabilizer to my rig. It is a 24' coach on a Ford E350 chassis. The chassis came with a stabilizer from the factory but I still have lots of issues with cons...
My camber is set at 3.6. The alignment shop refused to set it any higher. The mechanic said it would cause the steering wheel not to return to center after turns if it was set at >5. They said it met Ford specs and that was all they were willing to do.
