txhood's avatar
txhood
Safe-T-Plus
I am thinking about adding this steering stabilizer to my rig. It is a 24' coach on a Ford E350 chassis. The chassis came with a stabilizer from the factory but I still have lots of issues with constant steering input being needed. Also, issues with trucks pushing me around. The front end alignment has been checked and the tire pressures are correct. My rig is only one year old. Would the Safe-T-Plus be that much of an improvement over the stock stabilizer?
  • Harvard wrote:
    What was the front end caster set at? Should be > 5 degrees for best highway speed handling. IMO
    X2 That would be the first thing I would check. Get your coach weighed loaded as you normally travel and then take serious look at your tire pressure. As far as the movement you are feeling when the big trucks blow by there is nothing wrong. They are 80,000# going 75 or 80, trust me there will always be a serious "bow wave" of wind and it will move you. Keep one eye in that outside mirror as there is usually a lot more surprise than actual movement generated.
    I doubt a new E-350 needs any additional equipment to provide a smooth and steady ride. If it did Ford would have done so. Our 2012 E-350 drives and rides just fine but we are well under our weight limits, properly balanced, with the correct psi, all of which make a huge difference. :C
