3_dog_nights
Jul 12, 2018Explorer
Safe-t-Plus
OK, we are going to add the stabilizer. Where's the best place to buy it? I'll have it delivered to my local mechanic for the install.
wolfe10 wrote:
One of the few (very few) places I would disagree with Doug.
I would have an alignment done FIRST (yes, assuming an alignment is needed). I would not assume that the tech would loosen the Safe-T-Plus to take it out of the equation and then recenter it (which often takes several tries)
Because of the centering force of the Safe-T-Plus, it can be used to mask alignment, brake or tire issues. It can "correct" for a pull to one side that should be addressed by correcting the root cause, not using add on device to mask/correct it.
