bshpilot
May 25, 2015Explorer
if your gonna monitor Tire Pressure then you SHOULD monitor Tire TEMPS too....ala the TST System !
a Tire Pressure monitoring system allows you to check the pressure (without dragging out a hose, tank, compressor or a gauge)....just turn the monitor on and KNOW the pressure off all the tires (including the TOAD).
A tire TEMP monitoring system allows you to know of a potential failure or dangerous situation (including a stuck brake).
the TST system requires little if any attn. - it alarms on temp increase or pressure (pound or percentage) decreases (or increases).
