wa8yxm
Jun 28, 2014Explorer III
First: Happened to me.. Do you have an Intelletec Battery Control Center?
If so remove the 5 amp fuse that powers that switch, NOt sure which one, then remove all 5 amp fuses OR. if you are daring disconnect the switch from the harness behidn it.
Now operate the switch both USE and Store positions 50-100 times
Restore fuses, and or connector and see if it now works
If it does. Well.. There are two schools of thought
ONE: Buy lotto tickets cause it's your lucky day
Two: Do not buy lotto tickets cause you just used your allotment of luck for the week.
Pick one of those and act on it.
38,777 PostsLatest Activity: Jun 28, 2025
