Cbones's avatar
Cbones
Samsung RF197 refer replacement
I am contemplating the switch from my Dometic to the Samsung RF197. I would like to hear from others who have already made the switch as to how they are holding up in the mh. I have heard from some that this model has been problematic. Additionally, since I would like to not add any more batteries (I have 4 T-105s), have you noticed an increased drain on the house batteries? Can you make it through the night without having the genny start?any other tips or suggestions will be appreciated. TIA
  • DrifterRV wrote:
    The Samsung uses less power then the Dometic and runs just fine on a modified sine wave Inverter. We install ours two years ago with no issues.
    Less battery power than the Dometic running on propane?! Good luck!
    Jack H
  • I made the exact switch as you propose over 9 months ago without adding batteries (I have the same amount as you). It's the best thing I've done to my RV! It takes less amps than the old Dometic. I only noticed a .2 voltage drop overnight.
    Good luck, you'll wonder why you didn't do this earlier!
  • The Samsung uses less power then the Dometic and runs just fine on a modified sine wave Inverter. We install ours two years ago with no issues.
  • We have had ours for over a year and are very happy with it. It sat through last winter in -20° temps and this spring it still worked fine. Have at least 5K road miles on it and soon will add another 2 or 3K. Power wise, we do a lot of dry camping and the only addition we made was a 535A solar system 2 years before we changed to residential. We still have the same 4 battery house battery bank we always had and with normal use of all electric, we only have to use the generator every 3rd or 4th day to top off the batteries. Just wish we had made the change earlier, as it is nice to go to bed and not worry if the smoke alarm is going to wake us in time.....
