Bordercollie wrote:
Do you have a cap on the side of your rig where you can insert a filler hose ? This is where I use a funnel and add a cup of bleach in a gallon of water to the empty tank, then fill the tank, run all the faucets to circulate the bleach water and let the system rest for an hour or two before draining the system and refilling the tank. It's best to open the low drains valves when draining the fresh water tank, then close them firmly. You may want to drain the system again and refill the tank if you smell bleach in water.
This is the preferred method to use if possible. It's sensible without all the complications!
Brian
