hanko wrote:
Im sure alot of you fine folks have run into this. I have the winegard dome type satalite reciever which works fine but is sometimes blocked by trees or whatever. Can you plug like say a tailgater type reciever in the connection in the wet bay and have that take over. how does one switch between the roof mounted one and the portable? thanks
Well it is not that simple.. You may need to re-wire some
Some RV's have both a SAT in and a CABLE in,, in this case the short answer is yes, the longer answer is
Basement cable goes to the "B" input of an A/B switch (B-elow)
Roof cable goes to the A(bove) input of the same switch
Switched terminal connects via short jumper to receiver.
Option 2: If you have only the Cable in, then you need to either find the other end or, better yet (Cable cable tends to be low quality but some rigs do have good RG-6) put in a new RG-6
and use the A/B switch as above
The other end of the cable cable will run either to a wall plate with a switch, light, 12 volt outlet and antenna fitting, OR a box with namy buttons (Matrix switch) or to a Senssar Pro (Wall plate with 2 digital displays 3 buttons and around 5 LED lights)
Unhook and extend to A/B switch, run out to TV back to the switch. Turn switch off.
