rgatijnet1 wrote:
paschasmom wrote:
Thanks all for the information and opinions. I did some research and this unit was part of the recall. I still can't get the web site that will tell me if the unit was serviced. Still checking on that. For you National RV owners, are roll out drawers, under the dinette, standard? I've not seen that before. They are locked in place with a slide lock, pretty cool.
Since the recall was several years ago, the coach probably got a complete set of new brake calipers all of the way around. Now you do not have to worry about brakes and because it is not a Ford, you do not have to worry about the expensive spark plug problem Ford V10's are well known for.
One main reason that the Bosch brake calipers on the WH chassis froze up is lack of use. If this motorhome sat unused for a significant length of time, the problem may still exist even though the recall has been accomplished. As far as the spark plug thing, that was a very infrequent occurance. However, this and other forums blow it out of proportion because of the Ford vs. Chevy argumentors. I'm sure warts can be found on any make and model. Use your brain.
