We have a Sealand traveler China toilet. Had the floor flange seal replaced, hand held hose replaced,water valve,and flushing pedal replaced. It still leaks from the bottom. Any ideas.? Getting ex...
Sprayer is connected to vacuum breaker on backside of toilet after the water valve.
So anytime water valve is opened sprayer will have pressure/flow
Remove sprayer head and try just thru hose....sprayer head could be clogged.
If still no flow...then disconnect sprayer hose at vacuum breaker and check that stub connection on vacuum breaker has 'hole' in it. Stub comes sealed.......when optional sprayer is attached a hole has to be cut in stub.
