vickilea
Jun 21, 2014Explorer
Okay, the husband got the self contained sewer hose completed. This may not work on all coaches - but it works on ours and does not drag anywhere or has not hit anything on our test run. Here are the photos. He worked the flange to "pivot" so when you take the cover off and lower the pipe to the ground there is room for it to pivot. I'm SURE this can be improved - but the hubby love this and has nick named it "sh*ts away!" He did cut down the 90 degree angle piece and cut down the swivel flange so that it would not hand down that much - without cutting them it would have hung a lot lower. He glued the the flange to the 90 degree angle, The 90 degree angle to the 3' pipe is bolted together so that if needed it can be taken apart.
Click For Full-Size Photo.
Click For Full-Size Image.
38,756 PostsLatest Activity: Oct 02, 2025
