Can someone give me info. on potential problems. I have been told that if you spend a lot of time beach/shore camping that a coating of sand dust will stick to the piston which has a film of hydraulic...
We have spent years 100 yards from the Pacific ocean summering with the coach. I have found in my case the best thing to do is the day before we leave I wipe them down with A.T.F. and then a soft cloth. Use a Q tip and clean the outer cylinder seal. Then the next day they are good to go and retract within a two minute time frame. I will also do the same if in a particularly dusty desert environment.
