Esacnj
Aug 13, 2013Explorer
Self Levelers
Can someone give me info. on potential problems. I have been told that if you spend a lot of time beach/shore camping that a coating of sand dust will stick to the piston which has a film of hydraulic...
JimM68 wrote:PackerBacker wrote:
I'd be wondering why there is a film of hydraulic fluid on them to begin with, they really should be 'dry' unless they have been intentionally sprayed.
As mentioned already, a spray of silicon lube then wipe them down is what I would recommend. It's what my owner's manual states to do.
The seals are designed to weep a bit of fluid when extended.
Shock absorber seals are also.
