2chiefsRus's avatar
2chiefsRus
Sharp Microwave Oven Door
2007 Knight - original owners with original microwave. Finally had problems with the Sharp convection microwave this morning. The push button to open the door no longer works. Luckily I was preheating it so there is no food stuck inside. Anyone have any insight into how to get the door open? Do we need to take the microwave down to get at the broken spring or latch? Thank you for any assistance you can offer.
  • first see if you can find a part. You have gotten your money worth out of it. To get to the latch you will have to remove the control panel and you will see your issue.
    You were running it empty?
    It's a convection oven so it can be preheated.
    I took mine down to repair a problem...you need two people to remove it as it is very heavy and bulky.
  • Microwaves are cheap now. best to just replace it with newer and more efficient unit.
  • Probably you'd need to take it down, if you can't see anything else obvious.
    Be aware of the electrical hazards of mucking about in microwave ovens. Even with the unit unplugged, there's the potential for a lethal charge to be stored in the capacitor for a long time. Usually they have a bleeder resistor to discharge the capacitor when it's not in use, but if it failed the oven generally would still work fine and you'd be none the wiser. Microwave ovens are said to be about the most electrically dangerous common home appliance to work on...which is not to say it cannot be done safely by ordinary people, just that one needs to take care and be wise.
