timpittExplorer IIAug 16, 2023shifting on downhillsWe have a 2021 7.3 v8 fleetwood bounder 33c. Does anyone have info on shifting when going down hill and up hill. Other than the Ford manual?
dodge_guyExplorer IIAug 17, 2023Should always be in Tow/Haul! Anytime the engine is started, turn it on. When descending press the brake pedal. Each press of the brake will downshift the trans one gear. Don’t worry about the rpm, the computer will handle it!
Related ContentShift! **** You Shift!Schwintek slide jammed - shifted backshifting campertrans temperature downhillTC shifted
