wolfe10
Sep 22, 2013Explorer
Unless you are in a hurry, continue "worrying" it. Heat/cold with overnight soaking with penetrating oil. I use 50/50 acetone/ATF.
If that doesn't work, since it is a lower nut and you have access, I would use a hacksaw to cut through the nut parallel to the threads. Basically the same as a nut splitter, but you probably already have a good hacksaw.
38,780 PostsLatest Activity: Aug 05, 2026
