Gale_Hawkins
Sep 22, 2013Explorer
dakdave wrote:
nut splitters are a joke to try and use. if your shocks have a metal sleeve the bolts go threw many times the bolt will be rusted to the sleeve and you have cut both ends of bolt or cut shock eye apart.be sure and turn nut and not bolt if you can
Good point on rusty sleeve. Had to use saws all on one side two weeks ago to remove ATV rear shock.
38,780 PostsLatest Activity: Aug 05, 2026
