stubblejumper
Sep 22, 2013Explorer
Put a closed end (socket) wrench on the nut then use a floor jack to push up on it. Between the weight of the vehicle and the jack pressure the nut should break loose. For the uppers make an extender by cutting a notch for the wrench in a piece of 2x4 oak and push on it with the jack. Don't use spruce as it will just split.
38,780 PostsLatest Activity: Aug 05, 2026
