noteven
Sep 25, 2013Explorer III
RayChez wrote:
All you need it that Oxyacetylene torch you have and apply some heat to the nut, not the bolt. The heat will expand the nut to where it will break loose. We dealt with bigger then what you are dealing with all the time on the railroad.
RayChez is correct. Heat the bolt is for removing steel bolts / studs from castings.
38,782 PostsLatest Activity: Sep 20, 2026
