psalm10720's avatar
psalm10720
Shore Battery Switch not working well
I have a 1993 Brave 27RC and it has a Shore Battery Switch issue that mostly effects when I go to turn off shore battery power. I ordered a new switch and a new solenoid and am having those two things installed. If others have run into the same issue any helpful helps would be appreciated....
  • My battery disconnect latching relay acted up. Found that the control circuit was corroding on the inside where the coil attaches to the external stud.
    They are pretty easy to take a part.
    Cleaned the connections and has worked ever since. Coated with electrical De-Ox before putting back together.
    Maybe because I bought and carry a spare!
  • good luck with your question, not my issue. but i keep my cut-off, on the batteries..in... on.... position, to charge the unit.
