georgeant's avatar
georgeant
shore power only right side 110 v works
found one gfi in bathroom 2005 fleetwood pace arrow 37 c
all work with generator
  • In my 2008 Fleetwood, there is a gfi in the bathroom on the curb side and one in the bedroom on the driver side.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Ok, I will assume you have a 50 amp RV.. IF not, stop reading this post now
    IF you do read on...
    Possible suspect list: in line order
    1: Park power (lost a leg) NOT YOUR PROBLEM this is a park issue
    2: Circuit breaker: Park pedestal.. One half tripped, other did not,, Most people believe this is not possible, I have seen it with my own eyes.
    3a: Bad outlet (park problem)
    3b: Bad plug (your problem)
    3c: Plug only partilly in outlet (no problem, fully insert)
    4: Bad cord
    5: Same as 3 but the cord's outlet and motor home's inlet, all your problem though.. NOTE: Marinco Inlets and outlets you insert the outlet into the inlet and TWIST, this may be the problem, no twist.
    6: Screw loose, Marinco outlet or inlet (on my rig it was the inlet, on another the outlet ALL OF THEM)
    7: Bad cable inlet to Transfer Switch
    8: Bad transfer switch.
    My prime suspects are the circuit breaker (Park) plug/outlet junctions and loose screws..
    Many RVers have a few screws loose, but of course I spolied the joke by telling you what screws I am referencing.
  • If all the power works with the generator, but not shore power plug in, then you need to determine what is different between the two. Here's what I'd check first:
    1. Fault with the shore power pedestal.
    2. Are you using a different adapter with the generator than you are with the pedestal? If so, is that your cause?
    3. You aren't using a different power cord with the generator than you are with the pedestal?
