enblethen
Aug 18, 2019Nomad
The genset neutral must be grounded between the genset and transfer switch. So, yes connect white wire to ground bar.
Loose connections normally only need to be tightened. I would take each one complete loose one at a time. If the wire and connection point are of different metals, apply some good qulity de-oxidation grease. Then reinstall and tighten securly.
38,774 PostsLatest Activity: Apr 26, 2026
