Juddla
Aug 19, 2019Explorer
enblethen wrote:
If it did not drop out at junction box then there is issue betyween there and the transfer switch.
Do you have an enrgy management system?
Sir, I have no idea how there could be issue. I got same voltage at junction box off genny as stand alone then hooked wires up at junction box and got same voltage at ends that go into Transfer switch before hooking into switch, then hooked into ATS. AtS opens with correct voltage then voltage drops quickly and switch cuts out and volts build again and switch opens again this continues back and forth.
I’m not understanding how I would have issue between junction box and switch when I tested as stated above and had correct voltage?
I called Progressive Dynamics and asked for another switch which they are sending to me tomorrow. I have to assume this will happen again, so is there any chance the genny feels load and cant sustain 120 per Hot lines?
38,773 PostsLatest Activity: Apr 22, 2026
